A useful tool I found. (Cut ID Chamfer for Bowden Tubes)
Kwaad2
(@kwaad2)
I just wanted to post a useful tool that I fond that cuts the inner chamfer PERFECTLY into bowden tubes. (Similar to the ones pre-cut from Prusa come)
THIS drill bit, for boring holes has a wide enough blade/point to cut ANY bowden tube. (even if you have a 2.85mm printer)
Mine came sharp enough to cut the bowden plastic like hot butter. (No drill or anything needed, just use it as a hand-tool, and spin it with your fingers)
I was planning on just using a standard twist drill bit, when I saw this and thought. "hmmm... this is perfect!"
Tested it on a scrap piece of bowden, and it worked better than I could have hoped!
PS: If you do anything like this, MAKE SURE to get *ALL* loose PTFE off the ends/inside. PTFE *WILL* clog your nozzle!
Hi, I'm Sean. I used to work on CNC machines.
I try to not make mistakes, but the decision is YOURS.
Please feel free to donate to my filament/maintance fund.
Respondido : 05/04/2018 8:59 am
Re: A useful tool I found. (Cut ID Chamfer for Bowden Tubes)
You cant use that, its imperial size taper. Lol...
Joan
Respondido : 05/04/2018 6:50 pm
Dewey79
(@dewey79)
There are many results for "PTFE bowden tube", what would be a good supplier in the US and what characteristics should we look for?
Respondido : 05/04/2018 7:50 pm
