Suggestion for glues
warandv
(@warandv)
Guys
Do you have any suggestion for gluing metallic inserts in printed parts ? I dont want to solder them in.
I am looking at loctite ultra gel, not sure how it works on metal to plastic bond
I have brass, coated steel and stainless steel ones. Plastic is Colorfabb XT
Opublikowany : 30/03/2017 10:54 pm
neil.a
(@neil-a)
Re: Suggestion for glues
a Cyanoacrylate glue should be fine for securing parts , though a two part exoxy glue may also work for something with loose tolerances
Opublikowany : 31/03/2017 3:46 am
warandv
(@warandv)
2 part epoxies tend to be a lil messy.
Cyanoacrylate is superglue right ? Any brand suggestions for people in the US ?
Opublikowany : 31/03/2017 11:32 am
richard.l
(@richard-l)
Member Moderator
Loctite Ultra Gel should work just fine.
Opublikowany : 31/03/2017 7:17 pm
tobias.k3
(@tobias-k3)
2 component glue
But I find it much nicer embedding those pieces in the print. Just Insert a pause in the g-code - put thing in - continue printing
PRUSA MK2
- Noctua fan 40mm
- MK2/MK3 hybrid extruder
Opublikowany : 12/04/2017 11:34 pm
david.b14
(@david-b14)
Try super glue and baking soda for an instant weld.
Opublikowany : 16/04/2017 4:07 am
