per-filament gcode to adjust z offset
Jono
 Jono
(@jono-2)
I've noticed that with ABS, I need to adjust my z offset to -0.380, with most of my PLA it's -0.285, and with some other PLA it's -0.305.
Would be great to see a slic3r extension to specify this per filament type and have the printer auto-adjust.
Postato : 10/10/2016 7:15 am
martin.w3
(@martin-w3)
Re: per-filament gcode to adjust z offset
Have you tried changing the flow per filament? You can do that in slicer and it may take care of the issue.
Postato : 10/10/2016 11:14 am
martin
(@martin)
You can specify an additional Z-offset in the printer settings.
Postato : 11/10/2016 5:44 pm
Gobol
(@gobol)
Why not to implement such function? It would be pretty useful with Mk2. All we need is to provide additional custom setting for given material in slic3r and one another G-code command to set LiveZ during printing.
I dont have access to newest firmware sources, looks like they're not pushed to github, but I'd like to contribute such code...
Postato : 18/10/2016 10:55 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Yes they are: https://github.com/prusa3d/Prusa-Firmware/tree/MK2/Firmware
Peter
Postato : 18/10/2016 11:12 am
nuggetz
(@nuggetz)
Subbing to this.
Postato : 30/10/2016 9:48 pm
