[Chiuso] Heatbed cable positioning
einsundeinskundenservice
(@einsundeinskundenservice)
Dear fellow Printers,
after an interesting exprience with my y-Axis today I think I should adress the issue, how I fixed it and also what I would suggest to improve with the design. To start everthing off Iam using the Original Prusa MK3.
After I spent some time printing today I noticed that my Y-Axis wasnt moving all the way to the end of the axis and instead making some wierd noises. It turned out that the Heatbed-Cable got stuck in the Y-Axis and was blocking it (see pictures). Fortunately I realizied before the cable was completly torn appart and broken.
I assume that somehow the cable sneaked its way onto the axis and got stuck there since the cable is not fixed in place at all. I decided to put some iso-tape around it and fix it with tape to where it belonged.
Towards the Prusa-Team:
As far as I can see I think the issue would just be fixed by fixating the cable somewhere where it cant jump onto the Y-Axis Motor.
If you are having similiar issues and need further explanaiton on how to fix please contact me via E-Mail [email protected]
Best wishes!
Questa discussione è stata modificata 6 years fa da einsundeinskundenservice
Postato : 01/06/2020 9:00 pm
RE: Heatbed cable positioning
the thermistor wires are supposed to go above the aluminium Y carriage along the underside of the heatbed
Postato : 03/06/2020 12:09 am
Also your textured sleeve is supposed to be secured in the plastic mount too which it is not.  That is just asking for cable problems due to premature wear.
Postato : 03/06/2020 6:00 am
