Fast Way to Move Z Needed
mjsadaway
(@mjsadaway)
The firmware improvement I would most like to see is a fast way to move the extruder out of the way after an aborted or failed print.
Now, starting at the info screen, it takes 5 tedious steps. It drives me crazy every time.
I'll admit that I probably have more failed prints than the average user, since I'm testing various filaments with various build surfaces and encounter a lot of bed adhesion problems.
However, it does seem like the polite thing for the extruder to do is get out of the way.
Veröffentlicht : 30/10/2017 8:17 am
GertL
(@gertl)
Re: Fast Way to Move Z Needed
You can hold the button pressed for a couple of seconds, then you can move the Z axis. Easy enough i guess..
Gert
Veröffentlicht : 30/10/2017 8:52 am
JeffJordan
(@jeffjordan)
Mitglied Moderator
yes, it has been introduced a few firmware releases ago: press the knob at the LCD for more than a second, then you've got a shortecut to the settings -> move axis -> move z submenu and can lift up the z-axis by turning the knob clockwise.
➡ it can't get faster & easier (you just need to know it)....
Veröffentlicht : 30/10/2017 10:05 am
