Z-axis too low?
PharmDDad
(@pharmddad)
Z-axis too low?
Extra plastic surrounding feet of objects Extra plastic surrounding feet of included models on SD card
Ce sujet a été modifié il y a 4 years par PharmDDad
Publié : 25/01/2022 11:59 pm
It's difficult to say without seeing the underside of the model or a Z calibration print.
Bear in mind that the models supplied with the printer have specific purposes, most of them are intended to be easy to print for a first time user or to test the function of the printer.  The frog has a large area in contact with the build surface and is not tall enough for poor adhesion to become a significant issue ... and it's cute.
That said, your build sheet is dirty and unless you keep it clean adhesion *will* become a problem when you try some more challenging prints.
Welcome to the forums.
Publié : 26/01/2022 10:20 am
PharmDDad
(@pharmddad)
RE: Z-axis too low?
Publié : 26/01/2022 11:20 am
PharmDDad
(@pharmddad)
RE: Z-axis too low?
thanks for your response by the way!
Publié : 26/01/2022 11:27 am
RE: Z-axis too low?
It does look a bit too low going by the wave pattern in the first layer.  However your initial point about 'extra plastic' around the feet is not.  Thats a brim.  Its an option when slicing that produces an expanded area to increase adhesion for smaller or tricky parts.
You need to print something that doesnt have a brim and you only really need to print the first layer to check for your z height.  Something like the prusa logo has a reasonable area.  You can stop it after the first layer and check that its smooth, no wavy lines (indicating too low), no gaps when folded (indicating too high) but a single solid rectangle of plastic.
Publié : 26/01/2022 12:24 pm
