[Risolto] Y Layer Shift after Filament change
ColdNetsu
(@coldnetsu)
Utenti
Hello together,
every time i have a Filament switch i always have a Y Layer shift.
Checked the Belt Tension with a Belt tension tester. Looks fine to me.
Even with larger prints i have no problem with a shifts.
Firmware updated and all calibrations performed again. Same problem.
Does anyone have an idea what could be causing this behavior ?
Postato : 11/01/2024 10:27 pm
ColdNetsu
(@coldnetsu)
Utenti
RE: Y Layer Shift after Filament change
I was able to repair it. My Y axle was completely displaced. This didn't interfere with normal printing.
The customized printer head has 2 ways of attaching the PINDA sensor for reasons I don't understand. I had the wrong one.
As a result, the plate moved too far than was actually possible when changing the filament.
When moving back and printing again, it was shifted that little bit each time
Postato : 12/01/2024 2:42 pm
BAR
 BAR
(@bar)
I have this exact issue, but have yet to solve it.  Can you explain a little more on how you fixed it.
On mine, the next filament change would align properly.
Thanks
Postato : 07/09/2024 8:47 pm
