Which gluestick?
Which gluestick?
Which brand of gluestick do you use?
To this date, I have only used Kores.
Opublikowany : 19/12/2018 7:27 pm
thrawn86
(@thrawn86)
Re: Which gluestick?
I have never used gluestick even once.
pla, petg, pc, asa...PEI is great stuff.
Opublikowany : 19/12/2018 11:33 pm
You do nto have any issues with over adhesion?
Opublikowany : 20/12/2018 12:03 am
never got on with gluestick on 3d printers
on the mk1 with glass, I prefered to use ABS Juice.
on the mk2, mk2mmuv1 and mk3 I just use PEI stickers... and now Powder coat PEI
but only print PLA, PETG and TPU...
Opublikowany : 20/12/2018 1:35 am
thrawn86
(@thrawn86)
not unless it was my fault, too low live z for instance.
Opublikowany : 20/12/2018 3:11 am
At first, I had nto problem getting prints off the bed. Now, I have parts of the print, especially the brim, that stick to the bed and leave bits behind. I used a glue stick from Kores and it does nto happen any more.
Opublikowany : 20/12/2018 3:42 pm
carl.g
(@carl-g)
I use Elmer's School Glue Stick. The purple stuff. It's not common in the UK, but I got three sticks for a pound off Amazon the other day.
Easily the best one I've found.
I've tried other paper stick glues and they're mostly too soft.
I sometimes print directly on the PEI sheet, but with PETG it needs the glue to release IMHO.
Opublikowany : 20/12/2018 3:53 pm
RetireeJay
(@retireejay)
I always print with PETG, and the bed adhesion to bare PEI was far too much. I tried Windex, but that didn't work for me.
From experience with a previous printer, I had plenty of Scotch Craft Stick on hand, and that's what I used until the stick ran out. Then I tried the Kores that came with my MK3 kit - but it didn't have enough adhesion. So I'm back to using Craft Stick. The Elmer's School Glue (the kind that goes on purple but dries clear) is also fine; in my previous experience it bonds even tighter than the Craft Stick, a little more than what I want most of the time.
Opublikowany : 20/12/2018 4:17 pm
Thanks guys. I will give them a try. I never have a problem with PLA. PETG and ABS gives me fits not on some beds. I have found that glue sticks seem to reduce adhesion after cooling while still maintain adequate during the headed phase.
Opublikowany : 20/12/2018 7:29 pm
wavexx
(@wavexx)
On smooth PEI sheets? Do you use the same Z distance as PLA or higher? What bed temperature do you use?
I had two occasions where over-adhesion with glass and PLA itself ripped off huge chunks off the surface, so I'd like to avoid ripping off chunks of PEI 😉
Does gluestick in general affect the PEI sheet over time?
Opublikowany : 23/12/2018 1:47 pm
No. It washes off with soap and water.
Opublikowany : 23/12/2018 2:59 pm
thrawn86
(@thrawn86)
smooth sheet, yes.
I had a couple of cracks from a very long, heavily brimmed PC print that I was careless with and just ripped off with pliers, and a small chunk from some petg on the same spot and even then it was still 100% usable and I mostly ignored it. Prior to that I'd been using the same side of my original sheet for over a year without issue.
I ran PC at 280/120 for awhile but thats not needed at all, now I use 260/80. PC/PETG I use about .1-.2 less than PLA.
I absolutely destroyed the other side when I started a petg print after replacing rods and bearings without recalibrating Z and the nozzle buried itself into the PEI and manged to "print" a couple of layers before I noticed.
Opublikowany : 23/12/2018 9:26 pm
