What's wrong with the new Slic3r Prusa Edition?
Rob
 Rob
(@rob)
I've just downloaded the last version of Slic3r Prusa Edition and I cannot slice models correctly! Could anyone help? Below a model that I cannot slice (there is flying building).
https://www.dropbox.com/s/3ja33mki5m21g4i/HugeMaghetti.stl?dl=0
Moreover, I've been trying all day with a plethora of settings with another model, and the printer fails instantly when printing the skirt. Same models sliced with Ultimaker Cura print like a charm.
Cheers,
Roberto
Postato : 11/04/2019 4:35 pm
Nikolai
(@nikolai)
Re: What's wrong with the new Slic3r Prusa Edition?
Please provide more details what exactly is failing, not working. Screenshots would be also nice.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Postato : 11/04/2019 6:24 pm
Spacemarine
(@spacemarine)
I just tried your model, the STL contains 4825 errors. That's probabaly the reason why it can't be sliced correctly.
Postato : 20/04/2019 11:04 am
Utenti
I got errors also.
Postato : 20/04/2019 3:54 pm
Rob
 Rob
(@rob)
RE: What's wrong with the new Slic3r Prusa Edition?
Thanks for the answer and sorry for my silence but I did not see the notifications. I am wondering why Ultimaker Cura is able to slice and print the model like a charm.
Best,
Rob
Postato : 09/05/2019 9:37 am
Posted by: Rob
Depending on your settings, Cura may be running an auto-repair. You can do the same in Slic3rPE via File->Repair STL file... . Select your STL file, give it a new name for the repaired version, then try slicing that. I just did a quick test and it slices. Of course, no guarantees it'll print well.
Postato : 09/05/2019 1:25 pm
