What print settings were used by Prusa to print the Prusa I3 MK3 parts?
dimprov
(@dimprov)
I'm printing off duplicate extruder parts in case I melt mine with a volcano, and I want them to be as good as the originals that came with the kit.
For instance, what infill%? How many perimeters, top, and bottom layers? etc.
Anyone know?
Postato : 24/05/2018 11:46 pm
Re: What print settings were used by Prusa to print the Prusa I3 MK3 parts?
hI David,
on the page https://www.prusa3d.com/prusa-i3-printable-parts/
the information is
Recommended print settings:
0.2 mm layer height, infill 20% GRID and material PETG.
if you look on the right hand side, there is a ready made set of G codes, for the mk2s to Mk3 upgrade, this contains all of the extruder parts and an einsy case, ready prepared by Prusa,
this might help you.
Postato : 25/05/2018 12:56 am
dimprov
(@dimprov)
Thank you, Joan! I'm printing it now. I suppose the 20% infill is minimize the inertial mass of the print head.
With no layer guidance, I'm using 6 layers for the perimeters, top a and bottom. Hopefully that's a close enough match to what JP uses.
Postato : 25/05/2018 1:16 pm
