What is causing this weird filament tip?
Epic Space Models
(@epic-space-models)
After finishing a 6-8 hours print, the MMU2S automatically unloads the filament with the tip shown in the picture below (problem is reproducible).
This is causing the filament to jam when I start the next print.
The PTFE tube and nozzle are new. What could be the cause of this necked filament tip? I am thinking about replacing the heat break.
Opublikowany : 12/05/2020 12:42 pm
Jody
 Jody
(@jody-2)
RE: What is causing this weird filament tip?
Watching this post because I'm having a similar issue.
I am beginning to look at my new filament as the culprit but hoping the smarter people in this forum can chime in.
Opublikowany : 14/05/2020 12:48 pm
Epic Space Models
Actually, the problem started after I used a new silk silver filament that turned out to be a nightmare able to clog new nozzles even at 225 degrees.
Opublikowany : 14/05/2020 1:22 pm
Jody
 Jody
(@jody-2)
So, 4 days of trying to get this print to work with my new filament, but no luck. Switched to some older filament that I had left and VOILA!!!!
@epicspacemodels I am sure now that it is this filament. I'm going to try to use it for solid color prints but not for my Palette as it is too unpredictable. I will continue to monitor this chat.....just in case.
Opublikowany : 14/05/2020 7:32 pm
