Weird difference in first layer
progamer75
(@progamer75)
Hi guys,
Like you see in the photo, there is a little difference between the left and right section of the prints first layer. First layer should be optimal, but only this occurs (very small gaps in first layer). I calibrated my first layer very carefully and checked it with a model with one thickness high, so that could NOT be the problem.
Already contacted support, and they told me a very slight distance change with nozzle and bed. They advised to change the mesh lvl from 3x3 to 7x7, which should solve the issue. That did actually not, (made it a bit worse).
Anyone had this problem before, and solved it?
Many thanks!
Postato : 24/02/2022 6:39 am
That looks like a decent first layer.  I'm having trouble seeing the gaps you mention, they might be easier to see on a lighter coloured print - are the holes always in the same place or do they move around?
Postato : 24/02/2022 10:15 am
progamer75
(@progamer75)
Maybe this photo makes it clear. My first layer is indeed good, that's why I dont know what the cause of this issue is.
There are areas where the first layer is perfect, and then after a while, I got the super small gaps. I dont see these caps in my first layer on the top side. Its always the bottom side of the layer. I suspect the bed but dont know how to fix this
Questo post è stato modificato 4 years fa 2 tempo da progamer75
Postato : 24/02/2022 11:38 am
progamer75
(@progamer75)
RE: Weird difference in first layer
I did some testing. Could it be possible that it has something to do with the Panda probe? When the bed reached its temperature and I start the print right away, I always get these gaps. When I start a second print (when the bed is heated for a time), I got not a single gap?
I cooled down my bed, started the print again and yet again, my gaps were back.
Now I am doing some testing with letting my bed cooling down, start to heat again and wait a couple minutes before I start my print.
Postato : 24/02/2022 7:22 pm
Try drying your filament.
If your workspace is cold extending your warm-up period by a few minutes as you are experimenting may help.  Use the LCD controls to heat just the bed at first or you may get jams as filament bakes in the nozzle.
Postato : 25/02/2022 10:22 am
