Wave pattern and the Blob
Just cleaned the plate with alcohol and these blobs are persistent & parallel to the feed. Since they are firm I cannot run over the blob on the next layer. There is also this wave pattern perpendicular to the feed which I can feel on the print side but not on the bed side. The wave pattern is visible on the finished exterior surface.
Thanks in advance for any help. r.
Veröffentlicht : 04/07/2023 6:48 pm
RE: Wave pattern and the Blob
Wave pattern usually equals nozzle too close to the print bed. I'd adjust Live Z to move the nozzle up a bit. If it's too low, the nozzle will drag through the filament and can create blobs.
Veröffentlicht : 04/07/2023 9:05 pm
