        Vertical line (defect) on print surface (with ABS)
Hello,
some suggestions about the reason of this defect ?
file printed several time without problem with same material...ABS real good quality
in the last days we have this type of bad quality in the surface , with different file and in different positions ...
many thanks
                            Posted : 16/02/2021 10:16 pm
                    RE: Vertical line (defect) on print surface (with ABS)
I get those from time to time - and each time I check the sliced model preview - if theyr'e in the preview, there is no printer setting to help since they are in the model to start with.
                            Posted : 18/02/2021 4:30 pm
