Unlinking rectilinear fill from top fill pattern in Slic3r?
BIGRED
(@bigred)
I print a lot of functional carpentry things with my printer, and trying my hardest to use Slic3r as my only... slicer.
I want to print the top fill at 0 degrees, while the solid layers underneath at 45 / 135 as usual.
In Simplify I can set two different values for internal fill and top fill but can't figure out how to do it in slic3r. TIA! 😀
Veröffentlicht : 07/09/2018 6:55 am
Re: Unlinking rectilinear fill from top fill pattern in Slic3r?
I don't think it can be done with Slic3r currently. You can set an angle for fill overall, but not separate by top layers.
Veröffentlicht : 07/09/2018 7:10 am
BIGRED
(@bigred)
Yeah it seems that way, I'll stop clicking around in circles looking for a setting then 🙂
Veröffentlicht : 07/09/2018 7:48 am
Jerry
(@jerry)
I think you could use modifiers in Slicer to do this.
Veröffentlicht : 07/09/2018 9:45 pm
RedDawg
(@reddawg)
RE: Unlinking rectilinear fill from top fill pattern in Slic3r?
Is this just an appearance thing? If so, why not just rotate your model 45 degrees in the Z axis? That will essentially print all layers at 0 degrees (or 90 degrees, depending on which direction you rotate the model.)
Hear ye, Hear ye! Step right up folks and get your Government salvation here! Less than $.002 per word! Amazon.com/dp/B0B8XMMFP4
Veröffentlicht : 08/04/2021 1:13 pm
Swiss_Cheese
(@swiss_cheese)
@kenour
Yes, If I'm understanding your need correctly, this can be done very simply.
Here is a quick example I prepared using height range modifiers.  Layer Angles example
I rotated the example to your description, however I would have said it differently.
Enjoy,
Swiss_Cheese
The Filament Whisperer
Veröffentlicht : 09/04/2021 8:03 pm
Swiss_Cheese
(@swiss_cheese)
Oh wow this post is super old! I didn't realize.
Reddawg, this post is years old. 🤣
Veröffentlicht : 09/04/2021 8:18 pm
