Uneven sheet / 1st layer
Petr Klasna
(@petr-klasna)
Hi, do you have any suggestions what I can do with this? I would se generaly the 1st layer is quite good, but it seems to, that sheet is bent downwards in the center and upwards on the edges. Or is it something else? What can I do with that, please?
Napsal : 08/05/2023 10:31 am
https://help.prusa3d.com/article/bed-level-correction_2267
Napsal : 08/05/2023 12:08 pm
RE: Uneven sheet / 1st layer
Also are you using 3x3 or 7x7 mesh points ?
Napsal : 08/05/2023 12:39 pm
Petr Klasna
(@petr-klasna)
Posted by: @neophyl
3x3
Posted by: @diem
That looks like the thing I need, thanks!
Napsal : 09/05/2023 6:28 am
Before trying the bed level correction try switching to 7x7 points. It generally gives a much better result.
Napsal : 09/05/2023 7:07 am
Petr Klasna
(@petr-klasna)
OK, I didn't consider this option, so I'll give it a try, thanks.
Napsal : 09/05/2023 8:19 am
