Underextrusion /clogged nozzle after Ironing with 0.25mm nozzle.
Hondanickx
(@hondanickx)
Is there a way to prevent underextrusion /clogged nozzle after smoothing with a 0.25mm nozzle?
I recently printed  a small  mold  but had a clogged nozzle after every ironing pass.
I managed to print it succesfull to  " do a filament change"  and let it purge after every ironing pass.
Is there a way to prevent this?
Opublikowany : 18/08/2021 7:18 pm
filament
which filament?
Opublikowany : 18/08/2021 10:47 pm
Hondanickx
(@hondanickx)
Filament
Prusament pla mystic Brown.
All stock prusaslicer setting.
Opublikowany : 19/08/2021 7:17 am
In my experience even printing without ironing on a normal 0.4mm nozzle the chance of a clog is greater with Mystic Brown.   I had to up the temperature somewhat and live with a bit of extra stringing to reduce it and even then it still did occasionally.
Even with a forgiving filament, ironing unless perfectly tuned for flow percentage and speed is greatly at risk of clogging.  Its one reason that Prusa took so long to actually implement it.  I wouldn't have even tried ironing with mystic brown.  Couple that with a 0.25mm nozzle and its almost certain to clog.
Opublikowany : 19/08/2021 9:38 am
mystic brown.
Concur and Mystic Brown is tough to print or at least every roll I have owned.
Posted by: @neophyl
Opublikowany : 19/08/2021 9:40 am
Hondanickx
(@hondanickx)
Petg?
Ok thanks guys,didn't know the color would have such effect.
Would petg be better or worse to print such a thing?
Opublikowany : 19/08/2021 10:43 am
