Under extrusion with .6mm nozzle?
supernate91
(@supernate91)
I am using a .6mm nozzle and I cannot get my top layers to connect around edges. I have used the default profile in Slic3rPE for .6mm nozzles along with turning my extrusion multiplier to 1.02. This is an RC bumper at 100% infill. I first tried NylonX with the same issues so I switched to Inland PLA+ to dial it in. But i get the exact results with pla. I tried different infill patterns too.
Results (check the perimeters and around the bolt holes) The gaps.
Here are the print settings:
Posted : 09/08/2018 1:04 am
supernate91
(@supernate91)
Re: Under extrusion with .6mm nozzle?
Posted : 09/08/2018 1:05 am
supernate91
(@supernate91)
Have you tried
Joan
Posted : 09/08/2018 1:34 am
supernate91
(@supernate91)
Have you tried
Joan
Sorry i thought it was implied. I was using the default prusa preset for .6. I have that settings
Posted : 09/08/2018 1:40 am
I've been able to resolve such problems by adjusting Print Settings->Advanced->Infill/perimeters overlap to 50% using a 0.60mm nozzle. You've got it set to 25%, the default.
Posted : 09/08/2018 2:54 am
supernate91
(@supernate91)
fantastic. printing 1 new bumper now. Ill report the results
Posted : 09/08/2018 3:43 am
supernate91
(@supernate91)
MUCH BETTER!
Posted : 09/08/2018 5:50 am
