Unable to print nylon at all
jerry.g4
(@jerry-g4)
I am using Taluman Bridge Nylon and I am completely unable to get this to print. PLA prints 100% perfectly. The issue I am having is my Nylon will just not extrude properly. I am on a MK3s completely stock. When I load the nylon filament at 240c it will extrude properly but once I got to print barely anything will come out if anything at all. I am using the default Slic3r settings for Taluman Bridge. If I unload the Nylon then load PLA it prints fine again but once I put the Nylon in it will not print properly. I'm completely lost I've tried different temperatures turning down the print speed on my the printer upping the flow/lowering the flow. I'm not sure how all the Slic3r settings work. I've only been printing for a few months with only PLA nylon is my first exotic material. Any help or ideas would be greatly appreciated. I'm not sure if the Slic3r default settings are bad or I am just doing something completely wrong. I'm not sure if its a clog or a jam not really sure how to tell.
Veröffentlicht : 17/05/2019 11:21 pm
RE: Unable to print nylon at all
Are you sure it's not just floating off the bed? Nylon, including Bridge, won't stick to PEI at all without help. A layer of glue stick usually is enough, but you need complete coverage.
Veröffentlicht : 18/05/2019 12:35 am
jerry.g4
(@jerry-g4)
Forgot to mention I have glue stick down. On a 10minute print maybe 1-2 layers worth of material will have come out.
Veröffentlicht : 18/05/2019 12:41 am
Patrick McNamara
(@patrick-mcnamara)
Sound like you are having similar problems to what I am having, though perhaps a bit more severe.
Nylon frustrations...
You mentioned you have tried different temperatures, how high have you gone?  Taulman Bridge has a listed print temp of 250-255 and, at least for me, printing at the high end of the range for the filament seemed to work best.  Despite the 250-255 range, you might try going to 260 or even 265 and see if you get better flow.  Before you try printing, just load the filament, set the extruder about halfway up the Z axis and extrude into air.  Don't worry about the pile on the print bed.  It will cool enough during the drop that it won't stick to anything.  You should be able to get a clean, smooth filament stream when extruding into the air.  If you get to that point, then move on to trying a print.
If you can unload the nylon filament, put in PLA and print without doing anything else, you aren't clogging the extruder in any meaningful way.
Veröffentlicht : 18/05/2019 2:57 am
jerry.g4
(@jerry-g4)
I've done that exact thing I get nice clean extrusion when loading filament at higher temperatures but when it comes down to an actual print nearly no filament will come out. I can keep loading it through and it comes out fine but once I try to print it just wont right. I'm really stumped on whats happening. I've printed the exact part in PLA and it comes out fine I reslice the file for nylon and it just wont work. Since my post I've tried enclosing the entire printer in large box at 260 and still no luck. I really dont understand. when loading filament it will come out fine even at 240c.
Veröffentlicht : 18/05/2019 3:35 am
Patrick McNamara
(@patrick-mcnamara)
What nozzle size and layer height are you using?
Based on my observations, it seems that nylon is a lot "stickier" when melted than PLA.  Perhaps "more viscous" is a better description.  A first layer that was "miscalibrated" such that is was thinner than expected could cause issues.  Once you get the slightest problem with extrusion, it seems that all bets are off.  I don't know about Taulman Bridge, but the nylon I'm using is way more flexible than one would expect.  It's easily a flexible as some of the stiffer TPU formulations and the extruder has no problem shoving it out the side.
Veröffentlicht : 18/05/2019 4:02 am
jerry.g4
(@jerry-g4)
The stock prusa nozzle .4 . .2 layer height. Here is the print I was getting earlier and my best print so far. The best was just completed at 275c nozzle 100c bed at 50% speed and 80 flow in the printers settings. The print is supposed to be 100% solid but as you can see its nowhere near solid.
https://imgur.com/a/P0Ixu35
Veröffentlicht : 18/05/2019 4:10 am
Nikolai
(@nikolai)
I'm successful with Taulman Nylon 910 at 270C/90C 30mm/s 0.4 nozzle/0.2 layer height. Full enclosed (~40C), glue stick and no fan.
It's also important that your roll is dry! Nylon is getting wet pretty fast (couple days is enough).
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Veröffentlicht : 18/05/2019 4:16 am
jerry.g4
(@jerry-g4)
Posted by: nikolai.r
Any ideas https://imgur.com/a/P0Ixu35 this is what my last i'd call slightly successful print looks like. Supposed to be 100% infill .2 layer height.
Veröffentlicht : 18/05/2019 4:20 am
Patrick McNamara
(@patrick-mcnamara)
Printer settings meaning on the LCD display on the printer?
The settings  nikolai-r posted are very close to what I am using.  As for print speed, in Slic3R, go to the printer tab, and the speed menu.  In the upper "Speed for print moves" area, set everything to 30mm/s or less.  That will control your overall print speeds and keep them down.
Veröffentlicht : 18/05/2019 4:21 am
Patrick McNamara
(@patrick-mcnamara)
My filament prints like it is dry, when it prints.  I suppose I'll toss some in the oven for a while and see if it makes a difference.
Veröffentlicht : 18/05/2019 4:23 am
Patrick McNamara
(@patrick-mcnamara)
I've got some filament drying in the over this afternoon and will try printing again this evening with it.  I ran a test print this morning, with no retraction, and the first part came out quite nice.  The second printed the first few layers and then stopped extruding.
Veröffentlicht : 18/05/2019 7:52 pm
jerry.g4
(@jerry-g4)
Mine have all started coming out like your second picture. Which is much better than before at 275c nozzle 100c bed. with all speed at 25mms. What did you do to get the tall part in your picture coming out so well?
Veröffentlicht : 18/05/2019 8:17 pm
Patrick McNamara
(@patrick-mcnamara)
Posted by: jerry.g4
That's just it, they were part of the exact same print.  They are supposed to be the same part, just printed sequentially, instead of in parallel.  So it printed the complete one first, then started on the second and failed.  No pause, straight from one to the next.
I've just  started a print with filament that spent 8 hours drying at 80c.  It's three of the same part I printed this morning with all the same settings.  Same filament, just dried.  We shall see what happens.
Veröffentlicht : 19/05/2019 2:51 am
Nikolai
(@nikolai)
Posted by: jerry.g4
In general I can only tell you rule of thumb which works for me. Why your nozzle clogs is hard to tell as there are too many factors involved.
Do 20% infill first. 100% infill is sometimes tricky to print and try to use same settings with dry filament. The nozzle shouldn't clog.
Often linked posts:
Real Multi Material
Veröffentlicht : 19/05/2019 5:31 am
Patrick McNamara
(@patrick-mcnamara)
Dry your filament, even if its straight out of the manufacturers packaging, even if print quality does show signs of moisture.
Veröffentlicht : 19/05/2019 2:01 pm
jerry.g4
(@jerry-g4)
The lowest my oven can do is 70c. How long should I dry it?
Veröffentlicht : 19/05/2019 11:30 pm
Patrick McNamara
(@patrick-mcnamara)
I dried mine at 80C for about 8 hours.  I was originally aiming for 6 to 7 hours, but ended up being gone for a bit longer.  Longer than necessary is certainly better than cutting it short.
Veröffentlicht : 19/05/2019 11:35 pm
Posted by: william.m51
FWIW: PrintDry suggests nylon be dried at 70C for 12+ hours. I just think "overnight" and not worry about it.
Veröffentlicht : 19/05/2019 11:43 pm
