Un even height
MaksP
(@maksp)
Un even height
I'm having weird issue with printing this token.
Model is 4mm high and 19mm in diameter and printed with 0.25 nozzle, 0.15 layer height in the middle of build plate.
Left side comes out 3.4 mm instead of 4 mm with squished layers and slight shift.
Posted : 08/07/2022 10:40 am
RE: Un even height
It appears to be all around and could be where your infill starts.
Posted : 08/07/2022 11:04 am
MaksP
(@maksp)
RE: Un even height
Its where infill ends. Top par is hollow and bottom is solid up to that line.
Still not sure why  its shifting and one side is squished.
Posted : 08/07/2022 11:21 am
RE: Un even height
From your description, this could be an example of the "bulge":
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/buldge-when-print-reaches-solid-layers/
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/any-tips-to-get-rid-of-the-bulge/
https://forum.prusa3d.com/forum/prusaslicer/mitigate-wall-bulge/
TL;DR: Many suggestions, no universally applicable solution.
Posted : 08/07/2022 3:04 pm
MaksP
(@maksp)
RE: Un even height
Thanks for links Im Ill see if can find solution.
So can this cause shift in layers and squishing of one side?
Posted : 09/07/2022 4:35 pm
RE: Un even height
Shouldn't cause layer shifts. Like Chuck, from the picture I thought it was all around.
Common causes for later shifts:
  • Grub screws on X motor not properly tightened. One has to be tightened against the flat side of the motor shaft.
  • Belt not correctly tightened. Use this tension meter to get it right: https://www.prusaprinters.org/prints/46639
    X carriage over-squeezed. Loosen the back plate on the X carriage axis.
  • Nozzle hit an obstacle. Some patterns such as grid have lines that cross within one layer. This can lead to little pile-ups at the intersection points, in particular if you have slight overextrusion, which in turn can lead to the nozzle catching at those pile-ups. See https://help.prusa3d.com/en/article/infill-patterns_177130/
  • Zip ties on the wire bundle on the back of the extruder not properly positioned, so they or the cables hit the model.
Squishing on one side could be cooling related.  You can rotate the object and see if it persists.
Posted : 09/07/2022 6:01 pm
RE: Un even height
I concur.  This does not look like a layer shift at all.
Posted by: @fuchsr
Posted : 09/07/2022 6:48 pm
