Trouble with a specific texture
David Gordon
(@david-gordon)
I am having the strangest problem. Printing the floor tiles from the Dragonlock set here:  https://www.fatdragongames.com/fdgfiles/?page_id=2658
Printing on my Prusa MK3S with EcoTough PLA from Filaments.ca and while everything prints fine for the first while, as soon as I hit the 'rocky' tops of the tile, the printer jams 60% of the time or so. Basically, it stops feeding, although I can clear the jam just by ejecting the filament, trimming it, and reloading it. The filament always has a section where you can see that the bondtech gears have gouged out an area so that explains why it can't feed, but *WHY* is it doing this repeatedly at the same spot on these tiles. Even when I do get a completed print the tile tops aren't smooth and stone-like, they are pointy and rough.
Settings are using the .2mm Quality presets in Slic3r with the only change being that I add a brim and set it to 5 layers for top and bottom since the designer suggests that. My only thought is that since the texture is so uneven that the repeated action of extrude/retract/z-hop/extrude for small sections is grinding the filament.
What should I try to resolve this?
Napsal : 14/05/2019 4:17 pm
RE: Trouble with a specific texture
try reducing retraction length.
Default is 0.8mm
try 0.4mm
Joan
Napsal : 14/05/2019 8:14 pm
As Joan suggested ...
There is a mechanism that combined with a Prusa specific modification in the V6 heat break and large numbers of retractions the filament melt is pushed up into a wide region of the heat break, where it cools and jams.  Unloading the filament after a jam of this type reveals a 2.2 mm stub as shown here:
Napsal : 14/05/2019 9:42 pm
David Gordon
(@david-gordon)
Posted by: Tim
Bingo that's exactly what I was getting, followed up by the Bondtech gears chewing the filament.
So the solution is reducing the retraction?
Napsal : 14/05/2019 9:48 pm
I replaced my heat break ... lol.  But try Joan's approach first.  It can help 'prove' the theory.  You can also increase nozzle temp by 20c and sometimes that gets the transition zone that last mm up the heat break to where the issue goes away.
Here's an image of the special heat break: check where it changes from 2.0 mm to 2.2 mm ... if that step is at the plastic melt point there isn't a problem. If it is cool and the plastic solidifies, you get a jam.
Napsal : 15/05/2019 3:13 am
David Gordon
(@david-gordon)
Running a batch off now, so I guess I'll know in the morning.
Napsal : 15/05/2019 3:15 am
David Gordon
(@david-gordon)
So far so good.  Still printing when I left for work so I didn't check the texture but it didn't jam so that's a start.
Napsal : 15/05/2019 11:46 am
