Thin Curved Object
Spooknik
(@spooknik)
Thin Curved Object
Hello!
How would you go about printing this object? It's thin, tall and curved. I tried printing it standing up and it works but it's very unstable and the overhangs give some stringing. I added a brim and it seemed to help.
Prusaslicer does not seem to be able to generate supports for overhangs. I think if it could do that, it would add a lot of stability to the print.
Publié : 06/10/2023 8:48 am
That's quite an odd thing to print.
Is there any reason you cannot lay it flat on the print sheet to simplify the process?
Or just cut it from a sheet of stock plastic?
Your overhangs are not steep enough to trigger automatic supports.  Use the support painter to mark the overhang where you want support and reslice.
Publié : 06/10/2023 12:55 pm
Spooknik
(@spooknik)
RE: Thin Curved Object
Posted by: @diem
Yes it is pretty odd! It's for a lamp design I would like to try to 3D print.
The part is slightly curved and I don't think a sheet of plastic would work exactly. Maybe if I heat and bend it perhaps? 🤔
The biggest problem with laying it flat is that it is slightly curved on the z axis (the top overhangs the bottom). So it will not sit perfectly flat on the bed. This could work, but it's a lot of overhangs and probably will need a bit of sanding to get a nice surface.
Ideally, I would like to print them standing up because I can print 6 at a time. I need 72 prints of this part, so the more at once the better 😅
It seems like this might work, so i'll give it a shot.
Publié : 06/10/2023 1:33 pm
