Thicker lines around perimeter?
Neill Killgore
(@neill-killgore)
You can see in the pictures a couple of layers that look thicker than the rest on this print. That's happening on most of the prints that I do. Any way to troubleshoot this?
Postato : 31/12/2018 10:54 pm
toaf
 toaf
(@toaf)
Re: Thicker lines around perimeter?
I would check the belts, robs, and bearings.
I had the same thing, but when I rotated all my rods it got much better. I still haven't put my new rods and bearings in yet, but its still printing good
Postato : 31/12/2018 11:24 pm
thrawn86
(@thrawn86)
normal. check your seam/retraction locations in the gcode preview. The start/stop position for those layers is likely different.
here's an example, the seams for layers with the hole is different than the rest of the smooth wall.
Postato : 01/01/2019 12:50 am
Neill Killgore
(@neill-killgore)
Interesting. Is there anything I can can do to change that, or it's just the way it is?
Postato : 01/01/2019 2:56 am
thrawn86
(@thrawn86)
you can change the seam locations in slic3r. random, aligned, rear. s3d has the option to align to a point.
Postato : 01/01/2019 3:53 am
bob.h7
(@bob-h7)
Where does one read about seam location setting and under what conditions to change the default setting?
Just hunting and pecking around the internet?
Postato : 02/01/2019 3:49 pm
There are some excellent general references like this one on Matt's hub. Part of the problem is that the approach details may differ by printer (e.g. the Linear Advance feature described in that article is provided on the Prusa firmware) and slicer software. The slicers each describe the feature correctly, but may use different terminology and certainly use very different approaches. The fundamental problem is that layer seams -- start and stop points for each printed layer -- are a characteristic of the current FDM technologies. A layer has to start and stop somewhere, and it's not a perfect seam. We're left with trying to hide it in clever ways.
  • In my experience, KISSlicer provides the greatest array of seam hiding features. It's also, unfortunately, a very quirky and not often-updated piece of software. It does incorporate some "seam fuzzing" approaches that I think other slicers should consider.
  • Cura is next, providing options for hiding seams on inside or outside corners, and other capabilities.
  • Slic3r provides some basic features to move seams about.
  • Note that none provide an option to turn seams off. You can hide them. You can optimize your settings to minimize them. But you cannot get rid of them completely. This is a real problem if doing cylindrical layers with no corners in which to hide the seam. If it's a real problem, you're left with options for post-print finishing using traditional filler and sanding techniques.
    Postato : 02/01/2019 4:06 pm
    Vojtěch Bubník
    (@vojtech-bubnik)
    Utenti Admin
    Was this G-code sliced by Simplify3D or by Slic3r?
    Postato : 07/01/2019 6:29 pm
