Taulman Alloy 910
I have a Prusa MK3s+ with smooth PEI sheet. I used ELmer´s glue diluted in water about a ratio of 4:1. I spread it carefully with my fingers, but you can use a medium watercolor brush and put it on the printer´s bed and heat the bead, so the glue dries faster.
For the temperatures matter, just go with Prusa´s Slicer settings for Taulman.
For the brim, raft, brim and supports; that depend on the model. I suggest on support the ´´snug´´ option if not using soluble filament.
Publié : 22/11/2023 1:46 am
