Tall objects
Ionlab
(@ionlab)
Tall objects
I am having problems with printing tall objects. Like this for example
When I try to print the poles (150mm high) at some point everything becomes a stringy mess. I am using a brim to make sure that the parts are securely attached to the base. No issues there.
I also removed the spool from the top of the printer (in case it created more vibrations). Also slowed down to 50% in order to have even less vibrations.
Slicer used SlicerPE (Prusa PLA filament, infill 15%, brim selected and supports on base plate only) using the 0.2 QUALITY setting and using the default 0.4 nozzle.
Filament used Prusa (not prusament) PLA.
The best I got was 120mm before the stringy mess started.
Any recommendations at what to do?
Respondido : 08/03/2019 11:54 am
Re: Tall objects
A photo of the mess would help.
At this point, guessing the the part coming loose from the bed?
Respondido : 08/03/2019 8:03 pm
Ionlab
(@ionlab)
Re: Tall objects
Thanks for the response. The part was still fixed to the bed....looked as if the head crashed into the object or maybe a layer did not join with the previous...unfortunately did not take a photo of the mess.
Respondido : 08/03/2019 8:40 pm
Re: Tall objects
Tall parts can partially detach, especially if a brim is used, and look attached; they wiggle without much force and eventually fail. If a part is moving under the extruder, it's come loose or the part is too weak for the height and needs lateral supports.
Respondido : 08/03/2019 10:47 pm
Ionlab
(@ionlab)
Re: Tall objects
Thought a brim would make the part(s) attach better. So next time no brim.....How do I add lateral supports? Is there a setting in SlicerPE?
Respondido : 09/03/2019 6:25 am
Re: Tall objects
Brims do help keep parts attached: but they don't help much if the bed isn't clean, or if the part has a very small bed to height ratio. Printing a pencil vertically is problematic.
Slic3r PE doesn't have the ability to create lateral supports (that I know of).
Lateral supports are typically designed in when creating the part in your CAD tool.
Respondido : 09/03/2019 7:53 am
