Switching between Textured PEI Sheet and Smooth PEI Sheet
JMHaro
(@jmharo)
I've been a long time user of the Textured PEI Powder-coated Spring Steel Sheet ever since I got my MK3 but I wanted to do a couple items with the Smooth sheet.  Are there any setup steps I need to do before switching between the sheets?  I wasn't sure if they are directly swapable or if I actually need to do some alignments/calibrations when switching sheets.  I appreciate any information.
Best Answer by Ringarn67:
SmPEI sheet is thicker than textured sheet, about 0,35.
If you don't, well, you figure it out 😣
And read this https://help.prusa3d.com/en/article/steel-sheet-profiles_1955 very good instructions how to use steel sheet profiles
Napsal : 06/08/2021 11:36 pm
Ringarn67
(@ringarn67)
Go UP In Z!!!
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Napsal : 06/08/2021 11:51 pm
JMHaro
(@jmharo)
Thanks
Thank you, that's exactly what I was wanting to know and what I was looking for.
Napsal : 07/08/2021 12:32 am
