Stringing Issue on MKS3+
mitiapos
(@mitiapos)
Hello Everyone,
I have an issue about stringing. I tried a lot settings however ı didnt reach best result.
I share some pics which ı used settings.
Pls enclosed you can find some pics about results.
Which settings can I use?
thanks in advance..
Respondido : 13/02/2023 6:40 pm
I've expressed my very pragmatic perspective on this here before:
Dry the hell out of your filament. Run a temp tower to find the lowest acceptable temperature. Use a heat gun to take care of the rest.
Or if you have nothing better to do and love tinkering, go down the rabbit hole of trying to find an optimal solution in a multi-dimensional space of parameters you can modify simultaneously. Just to find out that you can start it over again for your next filament.
Respondido : 13/02/2023 8:00 pm
Crab
 Crab
(@crab)
RE: Stringing Issue on MKS3+
Likely humidy has gotten in as fuchsr has indicated.. you might also be using too high a nozzle temp.. the temp tower will show that.
But I've also had a lot of stringing when my brass nozzle got too worn and the opening enlarged significantly.
Respondido : 14/02/2023 1:59 am
mitiapos
(@mitiapos)
Humidity is impossible, because ı have just opened packet of filament and have tried. Issue is continuing . I have tried with nozzle temp is 190 celsius. the stringing was decreased however ı didnt reach good result.
Respondido : 14/02/2023 6:11 pm
RandyM9
(@randym9)
New filament ≠ dry filament.
There’s no telling where the filament has been stored or for how long.
There are many posts here on this very topic.
Good luck.
Cheers
Respondido : 14/02/2023 10:25 pm
SailorEric
(@sailoreric)
New filament is not dry filament. When a filament manufacturer tells me straight up to always dry brand new filament my guess is he knows what he's talking about. Yes, it makes a difference.
Respondido : 14/02/2023 10:42 pm
