Strange warp/edge on threads
What could cause this edges on one side of the threads?
Never had a problem like this before, the rest of the print is OK, no edges anywhere, only on threads. The edge is also at the top layer.
This is Prusament Jet Black PETG, 0.2mm quality preset, 3 perimeters, slicer 2.7.0 (also tried 2.7.2 after this - same).
RE: Strange warp/edge on threads
If it's on one side only it is probably caused by the airflow generated by the cooling fan which is cooling the model asymmertically due to the way it is constructed.
You could try to reduce the cooling in the filament settings or switch it off completely and compensate by lowering the temperatur and the print speed a bit but the print does look pretty good as it is, so you might just post process this instead of messing with the slicer parameters...
