Strange patterns on first layer, blobs generation
oli.lambert
(@oli-lambert)
Hello,
I am printing with mk3s+ for a few years now and I am very happy with it. I never had an issue I could not understand or fix but I am now facing a strange issue with last prints...
On first layer, I see kind of stripes like if too much material was added sometimes (just a feeling):
It causes small blobs generation on the extruder, ending on poor final result.
I am priniting prusament PETG with default settings. I tried with a textured and a satin sheet with same results. I replaced the nozzle (0.4) by a new one to be sure. I cleaned all axes and greased them...
I find it strange that the patterns are aligned but not with X or Y axis.
Any help would be appreciated.
Thanks in advance!
Oli
Opublikowany : 29/06/2025 12:53 pm
Your first layer Z calibration is a tiny bit too low.
- and the fine stringing suggests your PETG is damp.
Opublikowany : 29/06/2025 11:03 pm
oli.lambert
(@oli-lambert)
RE: Strange patterns on first layer, blobs generation
I will try increasing the z calibration a little.
Not sure about humidity: I was using a EIBOS 3D Filament Dryer CYCLOPES (was running for hours), so the filament should be dry...
Thanks
Opublikowany : 30/06/2025 7:03 am
