Sticky tacky spray paint on PLA plastic?
Pagina 1 / 2
AnnieR
(@annier)
Hello,
I've been trying to spray paint a piece I've printed and having a strange problem.
After 5 days, which should be more than enough to thoroughly dry any spray paint, plus an hour in the air fryer on low plus overnight, plus using that nail polish drying spray, it's still very sticky to the touch.
I tried a sanity test, painting a small wooden block, and it was thoroughly dry to the touch in an hour or so.
Oh, in case anyone wonders, I'm not some dumb chick who doesn't know how to properly do spray paint! I know how to shake the can and stand back and do several very light coats.
I've also used this very spray paint before (Krylon premium metallic) and never had any problems. It just seems to be related to the PLA 3d print plastic.
Any ideas?
Thanks in advance.
Postato : 22/05/2021 5:57 pm
RE: Sticky tacky spray paint on PLA plastic?
I recently painted a few large objects using Krylon's granite look paint. Took a while to cure - but the pressure in the cans was so high it blew the parts over and there was zero control - no such thing as a light coat. So the long cure time was expected in my case. Other Krylon and other paints I have used on PLA work just fine.
Krylon used to be good paint - after my latest experience with the granite, I have doubts.
ps: There's always a chance the can of paint you have is just bad - stored wrong /frozen before purchase, bad batch, etc.
Questo post è stato modificato 5 years fa da --
Postato : 22/05/2021 6:29 pm
Is this direct spray or did you use a primer?
It sounds like some solvent is penetrating the plastic and re-emerging at leisure.  Does a thin section of PLA soften when sprayed?
Cheeio,
Postato : 22/05/2021 6:41 pm
@diem
Good catch - it is a lacquer ...
Postato : 22/05/2021 6:48 pm
AnnieR
(@annier)
Thanks everyone!
No, I didn't use primer, and that's probably the problem. I shoulda thought of that.
Probably some solvent in the vehicle is melting the PLA.
I'll probably just do a reprint rather than try to remove the paint and prime and repaint.
Welp, off to Home Depot.
Thanks again!
Postato : 22/05/2021 10:26 pm
Utenti
Painting PLA is not as tough as PETG,
Postato : 22/05/2021 11:32 pm
Swiss_Cheese
(@swiss_cheese)
@annier
YOUR A GIRL!?!
The Filament Whisperer
Postato : 23/05/2021 12:55 am
Dan Rogers
(@dan-rogers)
@annier
They make paint just for plastic, but PLA is almost not plastic - very hard to get anything to adhere to it.  Try their plastic paint - the metalics are going to be very hard to get to stick to PLA - they're more enamels than laquers.   An acrylic water based paint will also stick very well to PLA, but you will need to follow that with clear acrylic to keep if from washing off if it gets moist again.
Postato : 23/05/2021 1:45 am
Utenti
@dan-rogers
Or, Use a plastic or pla compatible primer to increase adhesion.
Postato : 23/05/2021 12:17 pm
@annier
It may not be dissolving the PLA, it might just be wicking into the part along the lay.  Conventionally printed PLA is not waterproof.
Postato : 24/05/2021 6:42 pm
Utenti
Posted by: @diem
@annier
I have to concur.  If someone knows of a solvent to dissolve PLA, please let me know.
Postato : 24/05/2021 6:47 pm
Posted by: @cwbullet
Posted by: @diem
@annier
Is that a question Chuck or just more unrelated commentary? If a question, I suggest you do a search of the forums because solvents for PLA have been discussed many times.
Postato : 24/05/2021 7:31 pm
Utenti
@tim-2
I suspect the melting in the vehicle is heat related with PLA.  I asked an honest question.  I forgot the question mark.  Here you go:  Does anyone know of a solvent that melts PLA?  It is not that unrelated because it was mentioned above.
Postato : 24/05/2021 9:01 pm
AnnieR
(@annier)
Posted by: @swiss_cheese
@annier
YOUR A GIRL!?!
Yeah, uh, if you haven't figured it out by now.
And I'm probably old enough to be your mother! (If not your grandmother.)
But back to the topics at hand ...
They tell me that methylene chloride will dissolve and smooth PLA, kinda like acetone will with ABS. That's the stuff in those holiday bubble lites.
I haven't tried this yet but I've had good luck smoothing ABS prints with acetone and a mop brush.
Postato : 30/05/2021 4:54 pm
1 persone hanno apprezzato
Utenti
@annier
Thanks.  I try that.
Postato : 30/05/2021 5:01 pm
There's a fine line between "good sticky" and "bad sticky" sometimes. I'm with Chuck: This might be something that has other potential worth exploring. For paint finish, softening the plastic is definitely a bad thing. If you want an adhesive or smoother as in Chuck's case, it might be a good thing. @AnnieR - Sounds like these pieces are a write-off, but perhaps spray a couple and smush them together to see if it eventually hardens into a good adhesive? Are you getting any sort of smoothing effect, or just a sticky mess?
I've used various spray primers on PLA, but only acrylics directly on the plastic. My son has been airbrushing PLA scenery and miniatures I've printed for him. I'll ask what formulation he's using. Also curious if Krylon's plastic stuff is PLA safe.
I always enjoy Simone Giertz and Limor Fried's work. Creativity is universal and we all learn from each other!
Postato : 30/05/2021 7:38 pm
John
 John
(@john-6)
Posted by: @dan-rogers
@annier
I’ve used an enamel on PLA with no issues drying.
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
Postato : 30/05/2021 10:16 pm
Swiss_Cheese
(@swiss_cheese)
Posted by: @annier
@annier
YOUR A GIRL!?!
Well, if I'm being honest I don't really pay much attention to that around here, but you don't look that old in your picture 😋
But before you put yourself in the grave, old enough to be my mom would put you closer to 100 then I bet you are.
I suffer from the same thing on the internet, I always think everyone is a 26 year old kid.
Especially when they are a smart ass like me.
Enjoy, 😉
Swiss_Cheese
Postato : 30/05/2021 11:48 pm
Utenti
@annier
It is oh so genderist to say that only males 3d print.   Females to participate in mostly mail hobbies.
Postato : 31/05/2021 12:02 am
Swiss_Cheese
(@swiss_cheese)
@annier
Ok Charles, you've gone to far with that comment, the postal service is a fine institution, and many females work there as professionals, not just as a hobby.
Honestly I don't know what your thinking most of the time, please try to refrain from such comments in the future, it's very impolite, some might say chauvinistic.
Good Day to you sir,
Postato : 31/05/2021 2:28 am
Pagina 1 / 2
