Sphere Lampshade Print (top fails)
Dr. Mabuse
(@dr-mabuse)
i did buy a copy of a sphere lampshade and did some test-prints of the bottom and the top of the lamp before i start an 18h print.
I can print the bottom without probs in (esun) PETG and (esun) ABS+ but the top part always fails. This is the lamp shade
https://cults3d.com/en/3d-model/home/sphere-lampshade-3dprintlover
I cant publish the whole file here so here is the top part i try to print:
 Would you people consider this basicly as printable? If yes, can i do it with a 0.6 nozzle or do i  need to downgrade to a smaller nozzle? What would be the best approach to find out the correct parameters? I think i need to change print parameters for exactly this end part. The rest should print fine.
 Edit: It seems like i cant upload the stl file even its under 10MB?! (its 7.7MB)
Questa discussione è stata modificata 5 years fa 2 tempo da Dr. Mabuse
Postato : 19/07/2021 6:14 am
attaching files
STL files aren't an allowed file type.   Neither are 3mf project files which is what we need to debug issues.  Luckily .zip files are allowed, you need to zip up anything you attach.
Postato : 19/07/2021 7:23 am
2 persone hanno apprezzato
Catherine
(@catherine-2)
RE: files
@Neophyl
seems legit!
Questo post è stato modificato 5 years fa da Catherine
Postato : 19/07/2021 8:34 am
