Slowing down printer for small objects - possible?
Nirin
(@nirin)
Ok so I have a print bed set up with multiple objects, some large and some small.
The smaller objects, because they're more delicate, I want to be printed at a slower speed to prevent wobble and layer issues.
Now I thought that using the "Slow down if layer print time is below" and the "minimum print speed" would be the solution. And it is, if I only print a single small object, it does exactly what I need.
However on a print bed of multiple objects, it seems to only take into account the ENTIRE layer (eg. every object) and not the print move of each individual object.
So is there a way to slow down the print for short print moves? (I use Prusa Slicer)
Respondido : 09/09/2020 4:27 pm
jsw
 jsw
(@jsw)
RE: Slowing down printer for small objects - possible?
You can adjust the speeds in the slicer, or, in real time by simply turning the control knob counterclockwise (anti-clockwise) as the print is in progress.  You will be able to see the percentage of print speed on the front panel display.
Respondido : 10/09/2020 1:11 am
If you want different speeds for different models in the same print, modifiers are probably your best bet. I need to check to see what options there are for speeds (on mobile ATM).
In general, I just do separate prints for maximum control. I'd rather do 2 smaller prints that take a bit longer than 1 big failed print.
Respondido : 10/09/2020 1:52 am
Swiss_Cheese
(@swiss_cheese)
Have you tried Sequential Printing? and the "Slow down if layer print time is below" and the "minimum print speed"
The Filament Whisperer
Respondido : 10/09/2020 6:41 am
