Shifting x-axis while printing
Rob Holland
(@rob-holland)
While printing in ASA (Prusa) in an enclosure (temp up to 38 / 40 deg. F) it seems the x-axis shifts. I've printed this item several times before without any issue (wall thickness 2 mm) but now it has failed 3 out of 4 attempts. The layer shifts approx. 0.5 mm on different heights but only once per print.
Would there be a reason for a mechanical problem?
Any ideas??
Opublikowany : 16/08/2021 8:13 pm
Swiss_Cheese
(@swiss_cheese)
Check grub screws on X and Y axis, and if they arn't loose, then check your belt tension.
Good Luck
Swiss_Cheese
The Filament Whisperer
Opublikowany : 17/08/2021 2:48 am
Rob Holland
(@rob-holland)
Found the issue
The grub screws were all ok, the belt tension was also ok. I found the motor screws for the X-axis were a bit loose. After tightening all was back to normal.
Thanks for the suggestion!
Rob.
Opublikowany : 20/08/2021 8:40 am
Loose screw
Posted by: @rob-holland
Rob.
Good news - happy printing.  Have a loose screen can cause a lot of problems for a printer and people.
Opublikowany : 20/08/2021 9:54 am
