Sharp edge on top later
Sir Printalot
(@sir-printalot)
My printer (Prusa Mk3S+ w. Prusaslicer) has begun making a sharp edge on the final layers. See pictures below.
Do any of you know how to mitigate it in the slicer? I could mitigate it by adding a chamfer in the design, but that would just be ignoring the issue in the slicer or printer. This issue appeared recently. The printer is relatively new (6 months).
Thanks in advance 🙂
Napsal : 13/01/2022 4:32 pm
Swiss_Cheese
(@swiss_cheese)
RE: Sharp edge on top later
Just going by your image it appears that the part is lifting in the corner as its printing, also is known as warping, this can cause the type of blemish your seeing in the image.
The Filament Whisperer
Napsal : 13/01/2022 7:44 pm
Sir Printalot
(@sir-printalot)
Thanks. I tried with brim and raft to remove warping from the equation, but still no luck - the problem persists.
Napsal : 17/01/2022 5:06 pm
Bob
 Bob
(@bob-2)
Try a different plate orientation, maybe rotate it 45 degrees or something and see if that changes anything.
Cheers
-Bob
Napsal : 18/01/2022 1:43 am
