Several artifacts on Yoda bust
vidda1603
(@vidda1603)
Hello,
I'm quite new with 3D printing, and although I had some successful prints in the past 2-3 weeks, I don't know what went wrong here.
Problems:
  • Horizontal lines on the body
  • Ugly overhangs
  • Yellow line on the head
Can you guys help me what settings should I use?
Earlier I used gold PLA. Could the yellow line be caused by some stuck in the nozzle before this print?
Print details:
Material: Prusament PLA Bland Pearl White
Moldel: https://www.printables.com/model/152913-master-yoda-bust-star-wars
Slicer: Prusa Slicer 2.5.0
0,6 mm nozzle
0,15 mm layer hight
215 Celsius
Perimeter generator: Arachne
No infill
Speeds attached
1 mm retraction
Everithing else are based on standard Prusament PLA presets.
Napsal : 23/09/2022 11:45 am
RE: Several artifacts on Yoda bust
This is an overhang.  You could try slowing it down and turning up the cooling.  It also may need support.
Napsal : 24/09/2022 12:16 pm
vidda1603
(@vidda1603)
It was already around 60% of the normal print speed. Should I slow it down even more?
The cooling was also 100%.
For everyone else it printed fine without support...
Napsal : 24/09/2022 1:37 pm
