Selective Ironing
Rocky79
(@rocky79)
Selective Ironing
Is there a way to do disable ironing for a selected top surface in g-code?
I currently have selected Ironing for all top layers however there is one surface layer that I want the ironing to be disabled. See attached.
Thanks in advance
Best Answer by Ringarn67:
@rocky79
Look under, or rather to the right of, "Add Setting" 👍
Dieses Thema wurde geändert Vor 5 years von Rocky79
Veröffentlicht : 06/08/2021 9:46 pm
Swiss_Cheese
(@swiss_cheese)
@rocky79
you can do that easily using height range modifiers.
Enjoy
Swiss_Cheese
The Filament Whisperer
Veröffentlicht : 06/08/2021 10:53 pm
Rocky79
(@rocky79)
No Ironing option in height range modifier.
Thanks but I already checked. There is no option for ironing in height range modifier.
From what i see, you can modify few things infill, layers and perimeters.
Is there an option that I am not seeing?
Veröffentlicht : 07/08/2021 12:19 am
Ringarn67
(@ringarn67)
RE: Selective Ironing
@rocky79
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Veröffentlicht : 07/08/2021 12:43 am
Rocky79
(@rocky79)
Got it!
 I was in advanced, I needed to be in Expert mode.
Thanks for the tip. I appreciate it.
Veröffentlicht : 07/08/2021 12:55 am
Swiss_Cheese
(@swiss_cheese)
Thank you, ringard67 .I'm on mobile and could barly log in, the option is there, rocky. normally I would have asked you to post your .3mf and offers more insight , but the mobile version of this forum is freakin awful. If you haven't figured it out by tomorrow I'll offer more help, I'll be home then.
Since you weren't aware of the modifiers I'll assume you have some learning to do, sorry I couldn't help more via mobile, I blame prusa.
Regards
Swiss_Cheese
Veröffentlicht : 07/08/2021 1:00 am
Rocky79
(@rocky79)
@Swiss_Cheese I appreciate your quick reply. Thank you.
I use height modifiers all the time however I didn’t realize if I click on expert mode I would have an additional setting options. The extra settings are awesome.
Thanks again for all your help, I will check out the ironing options and will post more questions if needed.
Diese r Beitrag wurde geändert Vor 5 years 2 mal von Rocky79
Veröffentlicht : 07/08/2021 1:18 am
