ridge in one layer only
roc856
(@roc856)
ridge
See photo. Whenever I print this object, I get a ridge on a random layer. It doesn't extend for the full layer. As you can see, it joins the other layers about halfway along. Some more info:
1. Affects only one layer. That is, the ridge appears only once.
2. The layer affected varies.
3. I've tried changing my Live Z, from -1.25 to -1.7, in many steps, printing each one. At about -1.45 the print is greatly improved, in that the base is very smooth (much rougher at -1.25), but the ridge is still there.
4. It's not a layer shift, as the layers above and below the ridge are in the correct place.
5. Printer is calibrated, and the test reports that X-Y are correct and belt tension is in range.
Ideas?
Best Answer by Swiss_Cheese:
Your print it pulling away from the bed because of material shrinkage its long and thin shape exacerbates this condition, this is called warping, you can possibly over come this with a brim and well tuned temperatures for bed, filament and cooling. Print speed can play a part as well.
Good Luck
Swiss_Cheese
Veröffentlicht : 29/10/2021 6:30 pm
Swiss_Cheese
(@swiss_cheese)
Warping
Good Luck
Swiss_Cheese
The Filament Whisperer
Veröffentlicht : 30/10/2021 6:26 am
Dan Rogers gefällt das
roc856
(@roc856)
YES!!!!
Thanks, Swiss_Cheese!
I added a giant brim, and that totally fixed the problem. Now that I know what's going on, I'm sure a much smaller brim will do the job as well.
print with brim
Veröffentlicht : 30/10/2021 3:46 pm
Swiss_Cheese gefällt das
Swiss_Cheese
(@swiss_cheese)
Your welcome, and yep they could have saved the Titanic with that Brim 😉
I'm just guessing but probably a brim about 5mm would be more then enough. I can appreciate the better safe then sorry approach though.
Enjoy
Swiss_Cheese
Veröffentlicht : 30/10/2021 6:35 pm
roc856
(@roc856)
bed temperature
For another experiment, I raised the bed temperature from 60 to 70 and printed with no brim. Clean print! Then, as a double-check, I printed again at 60 and the ridge was back.
So, two solutions: brim or increased bed temperature. Probably a higher bed temperature won't work on all objects, so I might in the future have to have a brim as well.
Thanks again, Swiss_Cheese!
Veröffentlicht : 30/10/2021 8:15 pm
Swiss_Cheese
(@swiss_cheese)
@roc856
You have concluded correctly, there is hope for you Sir. both are tools and not all tools work for all situations.
But all tools are good.
Regards
Swiss_Cheese
Tool Junky
Veröffentlicht : 30/10/2021 10:12 pm
RE: ridge in one layer only
It may also help to sacrifice a goat in the name of the the Great Joe.... 😇
Seriously, often times 3D printing feels more like voodoo than science. There's just an ungodly amount of parameters and conditions that can be varied, and while often the results are predictable it never ceases to amaze me how how often they're not.
Veröffentlicht : 31/10/2021 11:02 am
Swiss_Cheese und Ringarn67 gefällt das
Swiss_Cheese
(@swiss_cheese)
The High Printest Has spoken
Bring forth the Goat.
Happy Halloween
Veröffentlicht : 31/10/2021 4:49 pm
