Reprinting fan shroud - Mk3S
Hi, I cracked the fan shroud on my i3 Mk3S during first assembly. Later during the process of clearing a blockage I broke it completely.
No problem! Just print another. So I printed a new one using e-Sun black PETG (I don't have any original black PETG Prusament on hand).
Printed fine with no obvious issues, however after a few prints, it has warped and now sometimes catches during printing.
I have printed with the recommended settings (0.2 mm layer height, infill 20% GRID) using the generic PET settings in PrusaSlicer.
Any thoughts? Bad material or something else?
RE: Reprinting fan shroud - Mk3S
Shroud is supposed to be printed with ABS, not PETG .
Ah that I can do. Got some black ABS. I thought all the printed parts were PETG?
Explains why the original part split along a layer line though.
Fan shroud is printed of ABS, the other parts PETG.
That makes perfect sense - ABS is much more heat-tolerant. They should put that onto https://www.prusa3d.com/prusa-i3-printable-parts/ . Right now it just says to print everything in PETG, with the only special note being to print the parts around the sensor in black.
