Reprinting fan shroud - Mk3S
FlyingPete
(@flyingpete)
Hi, I cracked the fan shroud on my i3 Mk3S during first assembly.  Later during the process of clearing a blockage I broke it completely.
No problem! Just print another.  So I printed a new one using e-Sun black PETG (I don't have any original black PETG Prusament on hand).
Printed fine with no obvious issues, however after a few prints, it has warped and now sometimes catches during printing.
I have printed with the recommended settings (0.2 mm layer height, infill 20% GRID) using the generic PET settings in PrusaSlicer.
Any thoughts?  Bad material or something else?
Napsal : 29/07/2019 7:12 am
RE: Reprinting fan shroud - Mk3S
Shroud is supposed to be printed with ABS, not PETG .
Napsal : 29/07/2019 8:07 am
FlyingPete
(@flyingpete)
Posted by: Tim
Ah that I can do.  Got some black ABS.  I thought all the printed parts were PETG?
Explains why the original part split along a layer line though.
Napsal : 29/07/2019 8:33 am
RH_Dreambox
(@rh_dreambox)
Fan shroud is printed of ABS, the other parts PETG.
Napsal : 30/07/2019 3:58 pm
Laird Popkin
(@laird-popkin)
Posted by: @rhdreambox
That makes perfect sense - ABS is much more heat-tolerant. They should put that onto https://www.prusa3d.com/prusa-i3-printable-parts/ . Right now it just says to print everything in PETG, with the only special note being to print the parts around the sensor in black.
Napsal : 18/05/2020 3:05 am
