Remove the small edge of the first layer
in-149
(@in-149)
I always have on my prints (MK3) a small border on the first layer (see photo). It's very light but it bothers me for this project specifically. Is there a tip to remove this border? (thickness of the first layer? Fans? T°?...)
Thank you thank you in advance, I'm a bit stuck on this point
Opublikowany : 31/07/2020 8:02 am
RE: Remove the small edge of the first layer
Try Elephants foot Compensation   (in the 'Print Settings>Advanced' Menu)
Regards Joan
Opublikowany : 31/07/2020 7:09 pm
Peter M
(@peter-m)
Elephants foot Compensation,settings in prusa slicer.
But also first layer to low,
bed to hot.
If you want to know how to remove it after printing, use a Ontbramers voor de kunststof industrie - Industriemespunt.nl
deburring tool
This post was modified 6 years temu by Peter M
Opublikowany : 31/07/2020 9:34 pm
juliette.l
(@juliette-l)
@joantabb
Many thanks for your idea. I am trying right now I wasn't knowing it !
Opublikowany : 13/08/2020 8:49 am
juliette.l
(@juliette-l)
I have tried to upper the layer but after I have some troubles but I will adjust between both points. Thanks for your help !
Opublikowany : 13/08/2020 9:01 am
juliette.l
(@juliette-l)
After several tests I managed to find the right parameters.
All is more than Perfect.
Thanks for your help @joantabb and @peter-m26
Opublikowany : 13/08/2020 10:10 am
