Prusament PETG on Texture PEI sheet issue.
Boltian
(@boltian)
Hello,
I have trying to print Prusament PETG on the Texture PEI sheet. The first layer calibration was OK, but when I try to print something I obtain the results shown in the pictures.
My current Z is -0.850mm. If I decrease this value (Increase the distance nozzle-plate), the adhesion is very bad.
May anybody tell me how I can solve this issue?
Thank you
Respondido : 20/12/2019 9:29 am
rmm200
(@rmm200)
RE: Prusament PETG on Texture PEI sheet issue.
Adjust your Z like in this article and post a picture of your result.
No point printing anything else until your Z is correct.
Respondido : 20/12/2019 5:21 pm
Boltian
(@boltian)
Thank you,
I've recalibrated the printer. The Z calibration provide for the firmware is not so good for PETG. I have calibrated according this picture:
As reference, these are my values:
Steel Sheet:
PLA: -0.520mm
TXT Sheet:
PLA: -0.850mm
PETG: -0.750mm
Another issue was the correct cleaning process.  I solved it with wiping with IPA the texture sheet with a towel paper pressing a lit bit to allow clean correctly the ultem micro cells.
Finally, I'm happily printing PETG.
Esta publicación ha sido modificada el hace 6 years 2 veces por Boltian
Respondido : 21/12/2019 9:56 am
