Proper bed temp settings to prevent warping
sebastian.w8
(@sebastian-w8)
Hello,
the left-rear corner of by print object is always warping (bending upwards), so I was thinking about raising the bed temperature by 5°C.
I'm using Prusa ABS. Which one of the three following settings would you choose?
  • First layer: 105°C - Other layers: 100°C
  • First layer: 100°C - Other layers: 105°C
  • First layer: 105°C - Other layers: 105°C
  • Best regards
    Postato : 18/05/2018 11:51 am
    Rosparovac
    (@rosparovac)
    Re: Proper bed temp settings to prevent warping
    For my project I raising temperature like yout 1 choice.
    But also:
    Made cover for printer.
    Use brim.
    "play" with correct Z distance.
    In case of nothing work ABS juice will.
    University: MK2S upgraded to MK3 with MMU2.0
    Home: MK3
    Materials: ABS; ASA; PETG; PET; PLA; Nylon; Nylon Carbon; CPE;
    SW: Freecad 0.18; Slicer PE And still generating more troubles than whole forum together.
    Postato : 19/05/2018 9:30 am
    LaPointe
    (@lapointe)
    French moderator and translator Moderator
    And I don't know if sebastian uses an enclosure, but this is something that is advised for printing ABS to avoid warping.
    Postato : 20/05/2018 6:00 pm
    Tiago
    (@tiago)
    120ºc/115ºc will prevent any warping with Prusa ABS
    I use this all the time, 100% success rate
    Postato : 20/05/2018 8:14 pm
    Rosparovac
    (@rosparovac)
    Yeah but 120°C is the limit (of PEI) and print "on the edge" all the time is not good, especially if you dont have to. I has been raising temperature only for one 25cm to 4cm knife print so far. All other projects inculing 18cm diametter circle dont need this hard core solution.
    Home: MK3
    Postato : 21/05/2018 1:33 am
    Tiago
    (@tiago)
    Well i hope PEI sheets would be avaliable first before i damage my unit 😀
    You can go 115/110ºc, works to me.
    I print 160x160x60 objects with prusaABS, no enclosure but i put a plastic bag to cover the printer
    You can also put a layer of glue or abs juice and print at 100ºc
    Postato : 21/05/2018 2:30 am
    sebastian.w8
    (@sebastian-w8)
    Hello guys,
    thanks for the replies.
    Yes.
    I assume you mean "First layer 120°C and other layers 115°C".
    Best regards.
    Postato : 22/05/2018 1:42 pm
