Proper bed temp settings to prevent warping
Hello,
the left-rear corner of by print object is always warping (bending upwards), so I was thinking about raising the bed temperature by 5°C.
I'm using Prusa ABS. Which one of the three following settings would you choose?
Best regards
Re: Proper bed temp settings to prevent warping
For my project I raising temperature like yout 1 choice.
But also:
Made cover for printer.
Use brim.
"play" with correct Z distance.
In case of nothing work ABS juice will.
University: MK2S upgraded to MK3 with MMU2.0
Home: MK3
Materials: ABS; ASA; PETG; PET; PLA; Nylon; Nylon Carbon; CPE;
SW: Freecad 0.18; Slicer PE And still generating more troubles than whole forum together.
And I don't know if sebastian uses an enclosure, but this is something that is advised for printing ABS to avoid warping.
120ºc/115ºc will prevent any warping with Prusa ABS
I use this all the time, 100% success rate
Yeah but 120°C is the limit (of PEI) and print "on the edge" all the time is not good, especially if you dont have to. I has been raising temperature only for one 25cm to 4cm knife print so far. All other projects inculing 18cm diametter circle dont need this hard core solution.
Home: MK3
Well i hope PEI sheets would be avaliable first before i damage my unit 😀
You can go 115/110ºc, works to me.
I print 160x160x60 objects with prusaABS, no enclosure but i put a plastic bag to cover the printer
You can also put a layer of glue or abs juice and print at 100ºc
Hello guys,
thanks for the replies.
Yes.
I assume you mean "First layer 120°C and other layers 115°C".
Best regards.
