Problems with Tunning, Printing , adhesion, over all mess.
Menglor
(@menglor)
Greetings,
I have a Prusa MK3S, I have had it for about 2 years now, and havent used it much,  I have restarted printing a few things, short version, its a HINGE for a Card Clock.
I was able to print 60 of the 77 I need, however, I changed my nozzle, from the brass supplied, to a hardend steel. as Well  I ran out of of my PETG spool, so I had to change that as well
since having to do this, I am cant seem to print a successful hinge to save my life.
- I have reset the wizard and re-calibrated.
- I have re-calebrated the first layer setting about a 100 times.
It seems to print the extrusion test layer pretty good, but when it does the calibration, its hit or miss.
but when it prints the hinge , it seems to get hung up in the nozzle,
I am looking for some calibration help or someone to point me to a video that will help.
I have to take a break every mins or so. or I am going to rip my ears off.
even when it was successful in the past, I struggle to print multiple copies of the hinge.
I was able to print 60 or so hinges, 1 at a time, when I tried to print 2,  fails everytime.
I suspect its all calibration, but I dont know anymore.
I would love some insight.
Napsal : 15/03/2022 1:17 am
RE: Problems with Tunning, Printing , adhesion, over all mess.
Did you try adjusting your print temperature? Hardened steel has a different profile than brass. When I played with a Nozzle X I had to adjust all my profiles up about 10 degrees or so. I'm now using tungsten carbide, which doesn't require any adjustments.
Napsal : 15/03/2022 11:47 pm
