problems with printing
carlos
(@carlos)
hello, I'm new with the printer but despite having assembled and calibrated without any error, the prints are constantly lines that do not print, I do not know if it is the extruder, which, several times I checked, or some of the axes I have raised the heat of the extruder by 5 degrees, I have reduced the printing time of the external walls, can not I do it, any idea?
Attachment removed
Opublikowany : 17/06/2019 9:11 pm
RE: problems with printing
What slicer are you using?
In any case, it looks like a problem with your slicer settings.  What profiles are you using?  What is the layer height?  What is the material?
Also - if you ZIP the stl and post it, we can have a look for design problems, too.  But I suspect the part is okay.
ps: please post photos in the forum; and use the LINK TO : MEDIA FILE setting.
Opublikowany : 17/06/2019 9:23 pm
