Problems using Cura for i3 mk3s/mk3 to print
Silverbubble
(@silverbubble)
So I downloaded the cura mk3s/mk3 profiles for cura.  The slicing process for a prototype i am trying to print out  seems to go fine, yet when i try to print it out, it says the file is incomplete.  I made sure all the settings were as described here: https://help.prusa3d.com/guide/how-to-import-profiles-to-cura-4-x-windows-macos_17848.   While I can't show exactly what i am printing due to it being a prototype for product development, I can say it is essentially a series of mostly flat plates with holes so it can't be due to the parts themselves.  I attached a picture of my settings if they help
Opublikowany : 22/09/2023 3:34 pm
Silverbubble
(@silverbubble)
RE: Problems using Cura for i3 mk3s/mk3 to print
update i see the nozzle is undefined in cura, how do i define it?
Opublikowany : 22/09/2023 4:19 pm
Silverbubble
(@silverbubble)
update 2: nozzle is now defined but issue persists
Opublikowany : 22/09/2023 4:22 pm
Silverbubble
(@silverbubble)
update 3: i turned my slice into a 3mf file, for some reason when i tried to open said file in prusa's own slicer, it wont read
Opublikowany : 22/09/2023 4:29 pm
