Problème lors de la premier couche
Good evening I come to you because I have problems when starting the printing of my gcode. Let me explain : when starting printing there are holes that form (perforated lines) during the first layer of printing, I redid the calibration which looked perfect, but the lines still form. I am attaching photos thank you for your help 😜
Opublikowany : 29/01/2024 7:40 pm
RE: Problème lors de la premier couche
I'd like to see the result of this after you dial in your Z-offset:
https://www.printables.com/model/251587-stress-free-first-layer-calibration-in-less-than-5
Opublikowany : 15/02/2024 4:21 am
