Problem with STL file
israel.n
(@israel-n)
I have prusa mk3 and I have problem with that file attachment.
When the printer start the print, immediately after the first circle then the layer fan start work and I must stop the printer
What I have to do?
https://files.fm/u/5wsh97nb
Postato : 31/07/2018 7:50 pm
Re: Problem with STL file
What slicer software and settings are you using? Can you post the gcode file you're trying to print? (a link to pastebin.com will work well.)
Postato : 31/07/2018 8:04 pm
israel.n
(@israel-n)
Here is the file
https://ufile.io/2jwd0
I’m set the regular settings not change nothing
Postato : 31/07/2018 8:12 pm
That is the same bloody file. Please don't link to dubious file sharing sites! What slicer software are you using and what settings? If you upload the gcode file as plain text to a site like pastebin, we can try to help you without exposing ourselves to malware. You have to make the same amount of effort to explain your problem as you expect us to respond with!
Postato : 31/07/2018 8:35 pm
