Problem with Prusa Petg and Slicer PE
CorpseGuard
(@corpseguard)
Hello there.
Last Night I start to print a venom bust and change to the new prusa mk3 FW.
The first 10layer went perfectly but then my Infill get broken. Big holes and after that it goes over to the support.
Veröffentlicht : 31/12/2018 4:47 am
thrawn86
(@thrawn86)
Re: Problem with Prusa Petg and Slicer PE
looks like its starting to air-print and jam. search how to do a cold-pull and further hotend maintenance if needed.
Veröffentlicht : 31/12/2018 5:10 am
CorpseGuard
(@corpseguard)
I dont think that. Because with other Petg I don't have this problem. Just with prusa filament.
Bad roll?
Veröffentlicht : 31/12/2018 10:03 pm
JMcK
 JMcK
(@jmck)
That’s PLA, not PETG. Right? Prusa only sells PETG in jet black and orange. That looks like Ms. Pink. PLA.
When someone asks you if you're a god, you say, "YES!"
Veröffentlicht : 01/01/2019 6:50 am
Spacemarine
(@spacemarine)
Not entirely true, they also sell PETG in other colors like green and blue. But you are right, they don't sell pink.
Which filament settings did you use?
Veröffentlicht : 01/01/2019 10:38 am
JMcK
 JMcK
(@jmck)
I, possibly incorrectly, inferred OP was referring to “Prusament” branded filament. But you are correct, they do sell other colors w/o the Prusament branding.
Veröffentlicht : 01/01/2019 3:48 pm
CorpseGuard
(@corpseguard)
Yes it was not prusament. I bought this before prusaments comes out. Now I try to print this in black with other Petg and it works.
Very strange.
Veröffentlicht : 02/01/2019 2:02 pm
CorpseGuard
(@corpseguard)
Here you can see its from prusa.
Veröffentlicht : 02/01/2019 2:04 pm
Spacemarine
(@spacemarine)
Does the filament "feel" the same in your hand as the other PETG filament? Or is it different somehow?
Veröffentlicht : 02/01/2019 4:52 pm
CorpseGuard
(@corpseguard)
Nope feels like the same.
Veröffentlicht : 02/01/2019 7:14 pm
JMcK
 JMcK
(@jmck)
Are there temperature specs on the spool?
That checkout clearly says PETG, but the only “transparent violet” on the site today is a PLA/PHA. I wonder if they mislabeled it when they sold it?
Veröffentlicht : 06/01/2019 3:29 am
Chris
(@chris-16)
From the pictures I am having trouble understanding what the issue is. are you saying that the infill is getting damaged by the nozzle?
if so dial back the flow rate so that it is not building up a blob on the nozzle and dragging it into the infill.
Veröffentlicht : 08/01/2019 6:10 pm
