problem with partly detached ledge inside cylinder
iainmalcolm1@gmail.com
(@iainmalcolm1gmail-com)
This is my first attempt at a print of my own design - just got the printer a few days ago.
It is part of an alternative lens cap for canon lenses. Most has worked fairly well, but there is a ridge on the inside surface of the cylinder, and the first layer that includes this ridge has pulled free for the cylinder and formed a chord, rather than following the surface of the cylinder.
I designed it with openscad and used prusa control to generate the printer file.
Will I need to switch to slic3r and do clever spells, or can I make it work through prusa control?
Here is the whole thing:
and here is deatail of one of the ridges:
Postato : 11/06/2018 3:53 pm
Gato
 Gato
(@gato)
Re: problem with partly detached ledge inside cylinder
Seems like you’re trying to print on air. Physics won’t let you. 😀
Try adding support. If slic3r adds too much then tree support from meshmixer will do.
Postato : 11/06/2018 5:38 pm
Lichtjaeger
(@lichtjaeger)
You could also add a 45° chamfer to this edges. They would make your piece printable without supports.
Postato : 12/06/2018 7:43 am
This has to mate to a metal bayonet socket with no chamfer, but I might try a very small angle one
Postato : 13/06/2018 6:40 pm
I'll give it a go, have to wean myself of prusacontrol first tho!
Postato : 13/06/2018 6:41 pm
